Conduit layout
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
272 Aufrufe, 1 Antwort
Conduit layout
Can I draw different type of conduits ( for RAW power, UPS power, CCTV, Telephone) by different colours ?? and How ??
1 ANTWORT 1
Nachricht 2 von 2
dzanta
als Antwort auf: Anonymous
yes you can.
1.  Start the Conduit command.
2.  In the Type Selector, choose which type you want to work with.  You can Duplicate a type and change their properties so each one is named correctly.
3.  Create the conduit runs
4.  Type in VG or VV to get to Visibility Graphics Dialog Box
5.  Go to Filter Tab and create a new filter
6.  Set the new filter to be the name of the conduit you want with the conditions you need (i.e. Description = RAW Power)
7.  Apply the new filter to the view and then change the colors/poche of the linework for that filter
repeat for each type you want...
See attached Revit file...
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
