I'm a little bit confused wth Revits cross section views. Sometimes rebar is shown correctly and sometimes it is like this (missing part of stirrups):
I've set host element transparency to "100" and made a perfect orthogonal cross section view!?
What else can I do? It's really annoying.
Regards!
I would say this is a view depth issue (far clip offset).
Can you post your drawing or only this part of it?
Posting your file would be better to check it.
Did you try setting deatil level to fine ?
What version of Revit are you using ?
I'll try to upload my file later!...It's a little bit big though....
Detail level is set to fine!
I'm using Revit 2018.2!
