Contacting Autodesk Support
Message 1 of 13
I get a notice that states "Data in file is corrupt and needs to be manually recovered. Pleased contact Autodesk support"." Yet there is no way to contact them.
How do I do this to recover and open this file?
Replies (12)
Message 2 of 13
wispoxy
Upload the file please, maybe I can do something for you.
There are many points of contact, Autodesk is a quality company with many users. They're crammed with support, your best bet is to share screenshots, errors, and lines of text with forum users like ourselves. A response from Autodesk may take up to two weeks.
Visit http://knowledge.autodesk.com/contactus
1. Select what we can help you with
2. Select appropriate subtopics from the pull-down menus
3. Select “I Still Need Help” and the option for Chat will appear
4. Click "Chat" button and you will be taken to the Live Chat
If you email support, allow 48 hours for a response. Weekends can delay response time further.
All support services are linked here.
http://usa.autodesk.com/adsk/servlet/index?id=1073074&siteID=12311
To contact and request a response by email from Autodesk Certified Instructors visit here.
http://aci.autodesk.com/contact-us
Email Autodesk Certified Instructors directly.
[email protected]
Message 3 of 13
I uploaded it? let me know if it works please.
Not badmouthing support by any means. Just couldn't and still cant find the way to contact them.
just frustrated is all.
Message 4 of 13
wispoxy
Sorry for asking for much. Now create a new drawing, a blank, and send it too me.
Message 5 of 13
Here it is
Message 6 of 13
wispoxy
Thanks. I'll need some time, my revit is down, I started downloading the trial version.
Download est. 56min remaining 26 of 30
Message 7 of 13
Thank you for your help! I am in a holding pattern until I can figure this out
Message 8 of 13
wispoxy
Pulled the basic info from your current Revit, still waiting on Revit 2017 trial download. Smiley Sad
Message 10 of 13
wispoxy
Good news and bad news.
The file in general is fine, an external reference is bad. So I'm trying to isolate the individual references, but Autodesk doesn't have an external reference manager like the one that comes with AutoCAD.
Your references as listed:
*307 BROAD RESIDENTIAL - ARCH - TB.rvt
*307 BROAD RESIDENTIAL - SHOR - TB.rvt
*307 UG_UT.rvt <--- I believe this one is the issue.
After isolation you would receive the working eternal files individually, and the broken one excluded. Allowing a good portion of the project to be recovered. If someone else could help me achieve this, it would be awesome.
Noticed a system date var. defaulted also. Which is most common when people are working on projects off corporate servers and managing external references, but not in all cases.
Being the fact I don't have an external reference manager, the task will take me a very long time. I'll continue working on it.
Message 11 of 13
I've narrowed it down to 3 items in my file that are pinned and wont unpin. Working on a solution to it
Message 12 of 13
Jacob.westergaard
Autodesk Support
Autodesk Support
Thank you for taking your time to write this in the forum,
There are various reasons for file corruption, it's a general thing with all kinds of files. However, there are some areas that are more common than others, such as:
  • Read/write failure to the storage media.
  • Program crashes (especially when writing data to the RVT model).
  • An add-in that modifies elements in ways not possible or desired through the normal UI.
  • Untested operations or series of operations (e.g. cancelling a synchronize, or using the Undo command after synchronizing).
Throughout the lifespan of Revit 2015 we have 14 updates where each one of them contributes to a functioning product. So if you haven't already, I would check that every single user is running the latest version and this applies to all our products - the Autodesk Desktop App will notify you every time there's a new update - it will be the same for whatever release you may be using.
Note: Updating will not correct already corrupt files.
As to you specific file, if you want I would be more than happy to go through the file and correct whatever might cause conflict.
I will just need you to confirm and I'll send you a link to a folder where you can upload your file.
In any case let me know how you would like to proceed, and if you consider my responds sufficient enough, please mark it as a solution.
Thanks again, have a great weekend,
Best Regards,
Jacob Westergaard
Autodesk Product Support Team
Revit/CAD Specialist
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
Message 13 of 13
Jacob.westergaard
Autodesk Support
Autodesk Support
Thanks again, have a great week,
Best Regards,
Jacob Westergaard
Jacob Westergaard
