I noticed that new Revit 2017 has problems with color schemes.
This is the simple case:
1) left image: one room between two boundaries (everything works fine)
2) after dragging one corner, room color jumps into another place (room area calculates fine)
Did you know how do deal with it?
There is an third image to prove that room is in right place, but color isn't.
Hello Robert,
I tried really hard to achieve the same but unfortunately, I could not get the same result as you showed in your pictures.
What Build of Revit 2017 do you have?
Did you install the latest update? Revit 2017.1
Hi Robert, thank your for quick answer.
There is a version of Revit and my RVT file (in new projects problem appears too).
PS. Today i found that wall splitting is solving this problem.
Thank you for your post. It looks like you are adding room boundary, tag, and type, and once the boundary is adjusted the color jumps to the interior walls. In this case, I see your file attached to troubleshoot (thank you) and I am in the process of reviewing this ill behavior. As of this time I would suggest the work around you have described to overcome this issue in the immediate future while I attempt to identify what may have happened and potential solutions moving forward. Thank you and I will be in touch with our findings.
