Conceptual mass glazing
I'm trying to create a conceptual mass that reflects a model for heat analysis in IES but I need to draw on the actual location of windows.
I am trying to follow this tutorial http://blendinmotion.blogspot.co.uk/2010/12/conceptual-energy-analysis-inside-revit.html however everytime I edit the surface as described but the form remains a shading surface, any ideas how to resolve this I'm sure I'm missing something simple
dzanta
1.  create your overall mass as normal
2.  select the face you want to work on...it becomes the current workplane
3.  use model lines to create the shape of the window on that face.  (ensure you have checked "make surface from closed loop" and "3d snapping" as well.
4.  select the new shape you just made and change it's material properties to glazing
repeat for all windows.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
This hasn't worked so far
I have screenshotted my process to explain
this is my intital shape
I use the settings as above to draw my shape
Change the style to glazing
but it still displays as a shading surface
Sorry double post
dzanta
ensure subcategory is set to mass glazing prior to inputting into project environment...
see attachment.
I am, but it changes.
I thought it could simply be as I have done model in place for the mass but it still doesnt resolve using a family
dzanta
send me your mass model
