Combining phases - rooms?
koleary_ksa
koleary_ksa
I have a multi-phase project that is complete and I am trying to clean it up to be an existing model for that building moving forward. If I start combining phases, what happens to the rooms? Do the rooms stay from both phases that are combined or do the rooms from a later phase stay while the earlier phase delete? Thanks!
vitorbortoncello
The rooms don't combine or delete; they remain based on the phase you're working on
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
HVAC-Novice
You can vote on these ideas to allow that:
https://forums.autodesk.com/t5/revit-ideas/add-rooms-and-spaces-into-phases-and-design-options/idi-p...
https://forums.autodesk.com/t5/revit-ideas/phasing-rooms/idi-p/8650858.
Not being able to change phases of a room or space is a serious lack in capability.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
