So I'm creating a family of fence blocks. Some of them have text in the model. However, bearing in mind that sometimes, when laying out the masonry, it is necessary to simulate some blocks as "cut/broken", to make the blocks fit correctly. Therefore, I needed the "Cut block" parameters to be "True" when the "Height" and "Length" parameters were smaller than their original size. However, I cannot form this sentence in the Revit API.
Gelöst! Gehe zur Lösung
Gelöst von reinaldo_pinheiroQM74Z. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
