Combine Calculated Value
21 REPLIES 21
Message 1 of 22
3071 Views, 21 Replies
Hi ya'll,
I want to combine two Calculated Value, but since they're not parameters, it's not available from the list. Is this possible?
Derek
21 REPLIES 21
Message 21 of 22
syman2000
The X value is a dummy. So basically I reference the area and use the that to give me the dummy value. The formula read if(area>0sf, "X", "X"). Regardless if it is yes or no, it will give you X text. You can reference either metric or imperial area. As long as there is a existing parameter, you can create dummy text out of it.
Message 22 of 22
in reply to: syman2000
Wonderful, thank you!
Forma Design Contest
