Trying to create a dish-shaped Floor using following steps...
Step 1: create dish-shaped Mass [check]
Step 2: create dish-shaped Mass Floor from Mass [fail]
Step 3: create dish-shaped Model by Face > Floor from Mass Floor [fail]
I can create a dish-shaped Model by Face > Roof from dish-shaped Mass, but the floor is flat.
I'm guessing this is how it is with floors, or am I missing something?
Solved by barthbradley. Go to Solution.
That is not how mass floor works. They are flat floors created by intersecting levels with a mass form. You need to create roof by face instead.
Is there a good workaround for adding a thickened edge to a Roof or Wall "slab"?
Wall Sweep, Roof Gutter, Roof Fascia, Model In-Place.
Post what you have and I'll tell you how I'd do it.
