Colored Room Tags
7 REPLIES 7
Message 1 of 8
2308 Views, 7 Replies
Colored Room Tags
I'm using a colored room tag on my floor plans. However, when the tags reach the stairway, the color is "hiding" under the steps. In some stairways a portion of the steps are colored and the other portion are the default white. In others the entire stairway is the default white color.
I have tried
1. recreating my tags
2. cutting a section and adjusting the height of the tag to go above and below the stairway.
3. and a filled region with the color I need instead
None of these options have worked.
Any ideas?
7 REPLIES 7
Message 2 of 8
Sahay_R
Can you share screenshot of the behavior + family?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 8
Are yoy talking about the room tag or the room element it self? If it is the room, I think stairs is white because it is a 3D object and it goes to upper floor. And the reasons you see different colours where the stairs is the cut plane height of the view.
Message 4 of 8
@Anonymous
I think you are confusing between a Room and a Room Tag.  A Room Tag always stays on top of any model elements no matter what (and you cannot adjust its elevation because it is an annotation object).
Solutions:
- Change the Room Color scheme to foreground
- Or, change the Stair category to 100% transparent
Message 5 of 8
in reply to: Sahay_R
let me know if these pictures help. I want my stairs to be yellow, not white.
Message 6 of 8
Message 7 of 8
@Anonymous
Have you tried the two suggestions above?
Message 8 of 8
Sahay_R
Use the Department Schema.
Rina Sahay
Forma Design Contest
Technology Administrators
