Hi there
Can someone take a look at this file attached
Every time I go into 3d view I can not see anything..
I don't know what is going on
Aidan.
Solved by barthbradley. Go to Solution.
If i really can't find a element i try to check off this list until i find the object.
Is this what you are looking for?
....I can't find anything else in the Project. I didn't check beyond Earth though. Maybe it's on another Planet? 😉
There are 3 CAD links. You don't see them in the 3D view because they are too far away from Project Base Point/Survey Point/Internal Origin.
I would insert them center to center then acquired coordinates instead of Origin to Origin.
Ah! I found your 22 0726 Site.dwg. It wasn't on another Planet after all. 😉
To get it to show up in Site Plan, uncheck all the other DWG imports under the Site Plan View's VGOs, and then change your Site Plan View's View Range Top, Bottom and View Depth Level to "Unlimited"
