- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Cannot log into Autodesk from Revit 2021.
- The login is button is enabled but when I click on it nothing happens, not even an error message.
- But the Render From Cloud button is enabled even though I'm not logged in. Isn't it supposed to be grayed out? When I click on that nothing happens as well.
- Otherwise the app works just fine, including regular Render.
- I went to the Autodesk site from my browser to make sure that I could log in to Autodesk and yes, no problems. But I didn't think that was an issue anyway, as the problem seems to be a technical issue from within the app.
- An interesting side note - the login button on Revit always appears in an Asian language (Chinese or Japanese) so I have to pulldown the menu for English. The app was installed in English.
- I just tried the sign in button from within AutoCad as well. Same nothing happens.
Can someone help me??
