Can't select linked model
Message 1 of 9
I cannot select linked Revit models. It is NOT an issue with my selection settings, you can see I have Select Links toggled on.
When I hover on a link, it shows a pre-selection box but when I click it, I cannot modify it in any way. It does show the green modify bar but the properties of the view remain, instead of the properties of the link.
I have encountered this in Revit 2019 and 2021.
Replies (8)
Message 2 of 9
cbcarch
Try selecting the Link in the Project Browser.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 9
syman2000
Check off the exclude options and see if you are able to select the link
Message 4 of 9
Modify it how?
What are you wanting to Modify?
Message 5 of 9
cbcarch
Maybe Room Bounding, or Phase Mapping?
Cliff B. Collins
Message 6 of 9
Ah! I misread the OPs screenshot. I thought it was showing Link Properties. There not too much after that except what you mentioned.
Message 7 of 9
Halfway there, the properties showed up but everything is greyed out. I tried Right-click>Make Element Editable to no avail...
Message 8 of 9
No luck
Message 9 of 9
"Right-click>Make Element Editable"???  What the heck are we talking about here?
