Can't select linked model
I cannot select linked Revit models. It is NOT an issue with my selection settings, you can see I have Select Links toggled on.
When I hover on a link, it shows a pre-selection box but when I click it, I cannot modify it in any way. It does show the green modify bar but the properties of the view remain, instead of the properties of the link.
I have encountered this in Revit 2019 and 2021.
Replies (8)
cbcarch
Try selecting the Link in the Project Browser.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
syman2000
Check off the exclude options and see if you are able to select the link
Modify it how?
What are you wanting to Modify?
cbcarch
Maybe Room Bounding, or Phase Mapping?
Cliff B. Collins
Ah! I misread the OPs screenshot. I thought it was showing Link Properties. There not too much after that except what you mentioned.
Halfway there, the properties showed up but everything is greyed out. I tried Right-click>Make Element Editable to no avail...
No luck
"Right-click>Make Element Editable"???  What the heck are we talking about here?
