I've created several fill regions and I've can't select to adjust the boundary.
Solved by ToanDN. Go to Solution.
Please upload a screenshot or something to know what you are talking about
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Check if you have Lines hidden
Do you have pinned the fill region?
Thanks for you post,
I enabled select by face -
I can now select the fill region, but something weird is happening;
Please see attached.
Thanks for that. It works.
Note:
I didn't know that 'Fill Regions' incorporated 'Lines' setting in VG!
I thought they were independent.
If you use <Invisible> lines to draw the boundary then you can turn off lines and still be able to select and edit the region boundary.
