Can't pick region
8 REPLIES 8
Message 1 of 9
info
457 Views, 8 Replies
Can't pick region
I've created several fill regions and I've can't select to adjust the boundary.
8 REPLIES 8
Message 2 of 9
rxi.gg
in reply to: info
Please upload a screenshot or something to know what you are talking about
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Message 3 of 9
info
in reply to: rxi.gg
Please find attached.
How do you in VG, isolate filled regions?
Message 4 of 9
rxi.gg
in reply to: info
Check if you have Lines hidden
Do you have pinned the fill region?
Message 5 of 9
in reply to: info
Enable Selection by Face.
Message 6 of 9
info
in reply to: ToanDN
Thanks for you post,
I enabled select by face -
I can now select the fill region, but something weird is happening;
  1. The region is not pinned
  2. When I edit Boundary - there's no boundary i.e. No PINK line??
Please see attached.
Message 7 of 9
in reply to: info
Turn ON all Lines.
Message 8 of 9
info
in reply to: ToanDN
Thanks for that. It works.
Note:
I didn't know that 'Fill Regions' incorporated 'Lines' setting in VG!
I thought they were independent.
Message 9 of 9
in reply to: info
If you use <Invisible> lines to draw the boundary then you can turn off lines and still be able to select and edit the region boundary.
Forma Design Contest
