Hi everyone,
I'm new to Revit. I'm having trouble to place mass floors, it says "mass contains geometry that cannot be combined. Mass Floor, Volume and surface area won't be computed".
I'm not sure what's wrong. Could anyone please help me?
Gelöst! Gehe zur Lösung
Gelöst von PijPiwo. Gehe zur Lösung
Make upper and lower parts as two separate pieces.
The easiest would be to copy entire mass to clip board, paste aligned to the same place, edit one mass deleting lower part, repeat with the other deleting upper part.
There is something about the location of those two elements that revit doesn’t like and cannot combine them to create floors. I noticed that the corners and some edges do not line up. Is that how it‘s supposed to be? Fixing them, solves the issue.
Also, slightly relocating the object sideways solves the problem as well.
"Also, slightly relocating the object sideways solves the problem as well."
Was having the same issue here in 2022. Cannot believe this actually worked...
