Can't get rid of the blue glass in shading
studioPZDLB
Message 1 of 17
studioPZDLB
Hi, even after I changed the Glass material to a pale blue in Shading in the Material Browser, it still shows up as the dark blue. This is in the project, so no matter what it should follow the project setting. Why is it not doing it?
Replies (16)
Message 2 of 17
EATREVITPOOPCAD
My guess would be something messed up in that Revit family because your other windows render glass properly. Edit family, and make sure the material parameter goes to the glass geometry. Or you can upload the Revit project file here (delete super secret info you don't us to see) and we can take a look
The definition of insanity is doing the same thing over and over again and expecting different results
Message 3 of 17
studioPZDLB
The family seems fine, using the same Glass material with the same Graphic definition as the Project. I will have to delete too much information before upload. I'd save myself the labor and hope to see another answer that makes sense.
Message 4 of 17
Check if the glass in the family is actually associated with the material parameter or having the material assigned directly, or surface painted with a different material.
Share the window family if you can.
Message 5 of 17
I'll bet the Glass Geometry in the Family ain't associated to a Material Parameter.  Looks like you other ones are.
Message 6 of 17
studioPZDLB
This is the family under question. When I select the glass pane, it shows the material is Glass. When I open Material, the Glass has the desirable Graphics property which is not showing up in the project.
Message 7 of 17
That is the picture of the family.  Do you have the family itself?
Message 8 of 17
That's correct.
Now load that one into the Project. Overwrite Existing Version if prompted.  If it fails, then there is something very strange going on here. Post your Project File (RVT) here.
Message 9 of 17
lim.wendy
Hi Darren,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts? Please share your project file as well so they can take a look.
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 10 of 17
stefan_gokstorp
if you have a material with the same name in the project it sometimes doesnt write the information over.
try creating a new material in the family, name it test or similiar put in the setting you want. bind it to the material parameter and load the family into the project.
Message 11 of 17
studioPZDLB
OK I'm attaching the family file. Strangely when I look at the elevation of the window in Shaded mode in the Family in , it looks very blue, although the Shading setting of the Glass is a pale blue.
Message 12 of 17
Use another Material.  Works here.
Message 13 of 17
studioPZDLB
What do you mean by "using another material?"
Message 14 of 17
Transfer Project Standards from a clean project (Architectural Template recommended) > Materials > Overwrite Glass.  Do it in your project, then save the window family from the project to overwrite the external family.
I attached a fixed family here just in case, but it means nothing if you don't fix any projects you already loaded the family in.
Message 15 of 17
studioPZDLB
It worked! Thank you! So the Glass material in the original file was corrupt?
Message 16 of 17
I don't why all the gymnastics.  It was easily fixed by doing what I told you above. Change the Material.   Bada Bing!  10 second solution.  Max.
Message 17 of 17
mauarduz
Hello everyone, I am dealing with the same issue, the material assigned to the curtain wall/storefront panels is clear, showing as clear in perspective 3D views, but it remains blue in elevation views, all view setting are the same, how can the material be different in another view? Help please THX --
