Voids in group cutting base model elements
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
stephenTNU44
453 Aufrufe, 5 Antworten
Is there anyway to prevent the voids within groups cutting through other groups and base model generic elements? Every time I copy and rotate or simply copy a group, all of the voids tend to cut through generic models in the base model (ungrouped generic models).
I am going through each time and need to "Uncut" the geometry... a bit redundant.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: stephenTNU44
Make them different families and nest one (more simple family ) into the other (more complex family).
Nachricht 3 von 6
stephenTNU44
I was concerned that would be the only answer. Very difficult to work across multiple families when I need the geometries to interact and align with one another in very intricate ways.
So there's no toggle switch anywhere that tells voids within groups to only cut geometry in their group? why would this not be the default??
Nachricht 4 von 6
Something doesn't add up here.  Can you post the file?
Nachricht 5 von 6
stephenTNU44
Here it is - Every time I copy, or rotate/copy a group, the voids within will cut other separate groups and the base geometry
Nachricht 6 von 6
I definitely use a nested component for each of your model group.  It is much more easier to constrain them when they are nested.
