Can't get rid of colors on walls HELP!
14 REPLIES 14
Message 1 of 15
gnarkill283
6223 Views, 14 Replies
So we've inherited a revit model from a company that we can't communicate with, and after trying to turn off graphic overrides and checking material colors, we are unable to remove colors showing up on our exterior walls. I don't know if this is caused by something similar to color schemes used with the color fill legend which colors rooms based on the name of the room. There must be a certain parameter making this wall grey even with overrides turned off. Appreciate any help. Thanks.
14 REPLIES 14
Message 2 of 15
semko_dm
in reply to: gnarkill283
Hi!
Did you check filters?
Сan you please post some screen shot for better understanding?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Message 3 of 15
gnarkill283
in reply to: semko_dm
Here is a screenshot of the model showing no filters. You can see some walls are white like we want them to be. I fixed some by changing the material shadow color to white.
Message 4 of 15
gnarkill283
Or is there anyway to create black and white elevations? I'm new to revit and I'm looking at model display options but seen nothing where I can simply make the view black and white
Message 5 of 15
Make sure the wall material surface patterns are not solid colored hatch. It looks like it is the case for me.
Message 6 of 15
semko_dm
Pick "hidden line" visual style.
Dmitriy Semko
BIM-Manager
Blog
Message 7 of 15
gnarkill283
I've tried hidden line. Some walls are still colored and all glass is colored still. This is really frustrating. I've changed the material of the surfaces to all white properites. I've turned the graphics property to white and turned off pattern. Some still randomly keep a strange color. Whats else can I do?
Message 8 of 15
artejon
Have you removed overrides both in V/G Overrides and graphics overrides by element in that particular view ?
If that is not the case then look at phase graphic overrides together with phase filter and phase parameters of the view in properties palette..
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Message 9 of 15
gnarkill283
in reply to: artejon
I'm returning to this problem because of a possibly similar issue that I'm having with this model - https://forums.autodesk.com/t5/revit-architecture-forum/make-transparent-fill-cover-entire-region-no...
I still haven't figured this out even after trying all the suggestions. I've checked all overrides, I've turn all materials to white, I checked phasing, and I've even copied 2 identical type walls into another new model and the colors still carry over (please refer to the attached images - the blue selected wall is white).
Message 10 of 15
gnarkill283
I've attached the new model (3MB) here if anyone can figure out how to turn the grey wall white I'd appreciate it greatly.
Message 11 of 15
PijPiwo
Your walls are painted. Use 'remove paint' tool.
Message 12 of 15
artejon
Remove a paint from a wall's faces (Modify>Remove Paint).
Tags (1)
Message 13 of 15
RDAOU
Hi @gnarkill283
it's the same issue causing ur problem on the other post...remove wall paint!
Message 14 of 15
gnarkill283
Thanks. That finally fixed that problem but I still have some random curtain wall windows that show up blue. How can I remove the color?
Message 15 of 15
JasonLLINDNER
@gnarkill283
Maybe you could copy and paste a portion of your curtain wall in a new project and attach it... Makes it easier to identify the issue and solve it instead of guessing
Forma Design Contest
