how to change wall color in plan view
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
48423 Aufrufe, 5 Antworten
Can someone please tell me how to change the wall color in plan view? It currently displays gray and I would like it to be black.
thanks!
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Are they under a previous Phase? Can you share a screenshot of the View and its properties palette?
Nachricht 3 von 6
rudi.roux
Hi @Anonymous
As @ToanDN mentioned, select your wall and scroll down to your "Phasing" in your Properties Pallet, make sure that it is set to "New Construction".
Apart from that, you can go to your Visibility/Graphics Overrides and apply a cut pattern to your walls as shown below.
I hope this helps! Smiley (fröhlich)
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Nachricht 4 von 6
FGPerraudin
hi @Anonymous,
Might be just in the properties of your wall.
If your view is in coarse detail , change the coarse scale display property in the family type properties:
see attached picture.
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 5 von 6
RDAOU
@Anonymous Hi
in not sure it's a phasing issue...that you will need to confirm so someone can guid u with phase filters
otherwise; considering the various types of walls on a layout (some filled and some not) when I want to use solid filled walls I would either
  1. use Course Scale Fill Pattern/Color (you can find that under type properties... select walls > edit type > Graphics )
  2. OR I would set up a Filter (by parameter)
  3. last choice and if it is global to the view I would override the visibility graphics of all walls (I rarely use this one)
Nachricht 6 von 6
als Antwort auf: RDAOU
Thanks everyone for your help with this!
