Can't create void profile
Every time  I use void sweep tool, the way to create a  profile grey out already. What is the problem dealing with? It's ok when I use normal sweep tool.Capture.PNG
It doesn't occur to you that the Select Profile button is available to click? Click on it first.
Yep, As u said, it bring like this . There is nothing to load nor sketch a profile.Capture.PNG
It's Ok now!  need to jump another tap.So confusing.Is that really need to be? Why don't bring directly ? Thanks for your answer bro.
Look at the tab.  Click on Modify | Sweep tab.
By the way, you cam always draw a Solid sweep and change it to Void after the fact.
suhruthchaitanya
You're not useful
