shared parameters.txt file position
3 ANTWORTEN 3
Nachricht 1 von 4
2016 Aufrufe, 3 Antworten
Hi all,
where is the sharedparameters.txt file position default on Revit 2019, please?
Thank you
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
It doesn't come with any. Just create a new one and save it in an accessible shared folder.
p/s: if you have Roombook/Areabook add-in installed then there are a couple of shared parameter text files for the add-ins but they are not supposed to be used for custom parameters.
Nachricht 3 von 4
RevitRx
here's how you create the .txt file. to get super technical, it is located in your revit .ini file (Directories Settings -> ExternalParameters)
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2019/...
www.RevitRx.com
Nachricht 4 von 4
If your just getting stared with Shared Parameter text files, I'll add that you should keep the file in a shared location that everybody can access -- a give it a unique name -- not just "Shared Parameters.txt".  Keep in mind , that Shared Parameters are "Shared" by virtue of their GUID -- not by their name.  So, if families get created using different Shared Parameter files, they will not be sharing the same parameter -- even if it's exactly the same name.
FWIW
