I am looking forward creating advanced symbols that could addapt for different scales. In some projects, I have multiples symbols next or close to each other. Sometimes I have to use parameters to move symbols located at the same place.
Nevertheless, the result is good only in that scale I was setting up my symbols' displacements. If I use a detail Callout and set it in a greater scale, symbols will have an offset from each other. Setting lower scale, symbols will clash ones to anothers.
I was hoping creating a family that have 2 symbols in there and configure them to show in different scales. I believe instance set up can't resolve this since an instance input of a family object is the same regardless the scale.
Hence, I would like to know if anyone knows a way to work with symbols of the same object/families in multiples views and multiples scales with the possibility to have different results for these diferent scales?
See attached images to understand what I am trying to solve.
Thanks in advance!
