I am trying to create a formula to calculate the diagonal length of the precast panel in wall schedule, but I am having trouble to come up with the correct synthax. This is how I am inputting it (Length^2+Height^2)^1/2, but coming up with wrong values. Any help will be appreciated. Thanks
Solved by RDAOU. Go to Solution.
Solved by barthbradley. Go to Solution.
Solved by eng.mostafa2414. Go to Solution.
It should be:
sqrt(Length^2+Height^2)
Mostafa Elashmawy
Sounds like you want to calculate the length of the hypotenuse ("c") of a right triangle knowing only "a" and "b".
c = sqrt(a ^ 2 + b ^ 2)
More:
https://www.revitforum.org/showthread.php/1046-Revit-Formulas-for-quot-everyday-quot-usage
@Anonymous
You were on the right track but you forgot the brackets (1/2)...Based on your formula it would be
