Calculated formula for diagonal length.
I am trying to create a formula to calculate the diagonal length of the precast panel in wall schedule, but I am having trouble to come up with the correct synthax. This is how I am inputting it (Length^2+Height^2)^1/2, but coming up with wrong values. Any help will be appreciated. Thanks
Accepted solutions (3)
MostafaElashmawy
It should be:
sqrt(Length^2+Height^2)
Mostafa Elashmawy
Sounds like you want to calculate the length of the hypotenuse ("c") of a right triangle knowing only "a" and "b".
c = sqrt(a ^ 2 + b ^ 2)
More:
https://www.revitforum.org/showthread.php/1046-Revit-Formulas-for-quot-everyday-quot-usage
RDAOU
@Anonymous
You were on the right track but you forgot the brackets (1/2)...Based on your formula it would be
