CAD links multiplying by itself
不适用
2,037 次查看
22 条回复
1 条消息(共 23 条)
不适用
Hi guys,
would really appreciate the help!
I have just few CAD links in the project but in the view templates there are a lot of multiplied links with the same name... I'm sure that noone have loaded them in. And this happened for the second time.
Last time in order to get rid of the links I had to use Dynamo to find all the links and delete at once. Unfortunately couldn't figure out how to select the links which I wanted to to delete, so I had delete everything.
Do you have any ideas why this happens and how to deal with it?
Thanks in advance for the help !
0 个赞
2,038 次查看
22 条回复
回复 (22)
2 条消息(共 23 条)
hmunsell
all the duplicates say "Cleaned" with what looks like a date after them. do you have any 3rd party Programs/Apps/Add-ins running in Revit?
Howard Munsell
0 个赞
3 条消息(共 23 条)
不适用
its just our naming procedure -  i've left the names ending to show that they all identical. They did not get renamed, just multiplied
0 个赞
4 条消息(共 23 条)
hmunsell
Do you have any 3rd party Applications/Programs or Add-Ins running though?
Howard Munsell
0 个赞
5 条消息(共 23 条)
不适用
only a printer and one of the diroost plugins. Nothing special and  I believe the first time it happened the plugin was not even installed .
0 个赞
6 条消息(共 23 条)
syman2000
Did anyone copy those CAD links or place them into a group? Normally it should be doing that unless there is a custom view template to set those CAD layers to different color, lineweight and linestyle. If you have sample, I like to take a look.
0 个赞
7 条消息(共 23 条)
不适用
nope, no one put them into any groups ... and the weirdest part that some links which I see in VG do not exist in the "manage links " and dynamo also cannot even find it in the project.
Unfortunately I cannot share this file, office policies.
0 个赞
8 条消息(共 23 条)
RobDraw
The problem may lie in the CAD files. Are they cross referencing each other? Have they been properly converted for use in Revit?
Rob
9 条消息(共 23 条)
hmunsell
is this only happening in this one file or can  you duplicate it in other files?
  • if so, can you make a new Revit file with 4 walls and some dwg's linked to it showing the issue (the DWG's can just have a line/box/circle in it for reference)? then post the file with the DWG's showing the issue.
Howard Munsell
0 个赞
10 条消息(共 23 条)
不适用
hmm, not sure what do you mean by "properly converted".  They were cleaned from unnecessary information and flying elements but that's basically it.
They they are not cross referencing each other - just some blocks inside might be shared
0 个赞
11 条消息(共 23 条)
不适用
this happened to this file for the second time and I cannot force fake it in another file. Once I remove all links and re-link them it works fine again.
0 个赞
12 条消息(共 23 条)
RobDraw
Not sure why you marked a solution.
If the files have anything within them that was created by a vertical product like Civil 3D or MEP, they need to be dummied down to vanilla AutoCAD.
Rob
0 个赞
13 条消息(共 23 条)
hmunsell
I just saw that pop up, I was wondering the same thing 😀?
@Anonymous what fixed it or lead you to the solution?
Howard Munsell
0 个赞
14 条消息(共 23 条)
不适用
sorry, I clicked it by mistake - solution is not found
0 个赞
15 条消息(共 23 条)
不适用
i will explore more this CAD procedure, but it looks like the files are pretty simple
0 个赞
16 条消息(共 23 条)
Mohamed-Nassar
Purge Unused CAD file from manage tab and from my point of view try to Link CAD no import cad
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
0 个赞
17 条消息(共 23 条)
Mohamed-Nassar
Check category of Window and it has Open Cut
0 个赞
18 条消息(共 23 条)
不适用
that's the problem - I cannot purge them as i cannot see the multiplied once in the manage tab. And as for the other suggestion - all CAD files are links not imports
0 个赞
19 条消息(共 23 条)
Mohamed-Nassar
So u have delet them already but may they affect Line pattern  and Filled Region only you can handle this by deleting them manually if u haven't dynamo script
0 个赞
20 条消息(共 23 条)
不适用
Dynamo finds only the main once, not the multiplied once - those I can delete only by deleting all links which isn't a solution now. But the main question is how did it happen? And if anyone has ever encountered the same issue?
0 个赞
