In the below image, the red lines would be soldier course and the red field would just be a different color brick to match the soldier course. Since this is on a curved wall, I can't do split face, and can't do sweeps.
Is doing this with another layer of wall my only option?
Wall Sweeps will host to curved walls. Curved Walls can be Split.
How did you create your curved wall?
Hi @bcollins
Can you share the model to test on our end?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
