New to Revit, using 2019.2
I've applied a parameter to rooms that helps me identify guestroom types; wondering if there's a way to select rooms using the filter function then refining that selection by parameters. thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
No. But you can create a Room schedule, add the parameter, group them into a single row using that parameter, select the matching row and highlight in model.
Example:
You can add Project Parameter(s) and then create a rule-based Filter(s) that references those Project Parameter(s), as well as create Schedule(s) that includes those Project Parameters. Then manage all those Project Parameters through the Schedule(s).
...actually, I can see a KEY SCHEDULE coming into play here.
