Hei!
I made a stair element in Revit and changed it, like I needed it to be.
Here it is:
But I didn´t find a way, how to get this kind of stair material quantities. For some reason it didn´t show up with other regular stairs in schedules. What I´m doing wrong?
Solved by RDAOU. Go to Solution.
How did you create the stair?
Create a Material Take Off schedule for Stairs >> Runs then add Material: Name and Material: Volume
In the example below I set the Monolithic Material of the Run to Cast in Situ Concrete ... see GIF below
