Assembled stair quantities
4 REPLIES 4
reginaTRCZN
362 Views, 4 Replies
Hei!
I made a stair element in Revit and changed it, like I needed it to be.
Here it is:
But I didn´t find a way, how to get this kind of stair material quantities. For some reason it didn´t show up with other regular stairs in schedules. What I´m doing wrong?
4 REPLIES 4
RDAOU
in reply to: reginaTRCZN
@reginaTRCZN
How did you create the stair?
  1. using stair tool
  2. ör as a model in-place extrusion?
    • If the latter, which category have you used? Stairs?
  3. Which quantities are you looking to extract? Volume?
reginaTRCZN
in reply to: RDAOU
I was using stair tool.
Yes, I want wolume of that stair.
RDAOU
@reginaTRCZN
Create a Material Take Off schedule for Stairs >> Runs then add Material: Name and Material: Volume
In the example below I set the Monolithic Material of the Run to Cast in Situ Concrete ... see GIF below
reginaTRCZN
in reply to: RDAOU
Yess, now I got what I want!
Thank you!
