I'm working in the structural model for a project. The architectural and structural grids had been coordinated and matched exactly. The architect sent an updated model and now all the structural and architectural grids are offset in the east/west direction exactly 1" in the structural model, but the architect is not seeing this offset in their model.
I checked the origin in the structural and architectural model and those match. I tried removing and reloading the architectural model, but that didn't work.
Any idea what might be causing this offset?
That doesn't compute. Are you saying the Architectural Link doesn't align with the Structural, but the Structural Link aligns with the Architectural? Are you sure everyone is working with the same Links? Doesn't sound like it.
....in one direction only? Sounds like the Survey Point Origin in the Structural Model got shifted to the left or right.
...moving the SP while clipped will move its Origin.
That is why establishing shared coordinates between models important. What could have happened was the Architect shifting their gridlines and the Structural link 1" whether intentionally or accidentally.
Before jumping into solving it, ask the architect to confirm the Internal Origin alignment between their model and the Structural link on their end.
Thank you both for your help! I asked the architect to check the origin and survey point in their model. The structural link origin and survey point are off 1" to the left in their model. There is not offset in these values in the structural model. Do you think this means the structural link was moved in the architectural model by mistake? Would it correct it just to move it back 1"?
@jmcqueen wrote:Thank you both for your help! I asked the architect to check the origin and survey point in their model. The structural link origin and survey point are off 1" to the left in their model. There is not offset in these values in the structural model. Do you think this means the structural link was moved in the architectural model by mistake? Would it correct it just to move it back 1"?
The Structural Link origin IS the Survey Point. The Internal Origin means nothing to Shared Positioning/coordination. It all about the Survey Point. I explained what might have happened above in the first Post.
...why don't you just reposition the Link and reconcile?
Thanks. I did read that, I just don't fully understand it. Could the architect have moved the survey point of the linked structural model, or would that have had to be done in the structural model?
When you Link two Projects together and Share Coordinates via Acquire or Publish Coordinates, the Project's Survey Points Origins are then aligned. If someone accidently moves the Survey Point Origin afterwards, it will drag the Link along with it.
...if no Link is loaded when the SP is moved, it doesn't matter. The Link IS moving too, whether it is loaded or unloaded.
Can you confirm if you link the architectural model in Origin to origin or by Shared coordinates?
You aren't sharing? Oops.
I would.
