Imbed family to elec panel family
9 REPLIES 9
Message 1 of 10
yes_and_no
348 Views, 9 Replies
Guys, I wanted to imbed an electrical service entry ESE family (the pipe with goose neck) to the OTB electrical panel.
The ESE is created from a two level base gen model family. I inserted it into floor plan of the panel. As i reload to project file, the pipe is laying flat down on the house floor.
I went back to the panel family trying to reinsert the ESE to different plane, RV won't let me.
Same thing with 1 level base family.
What can I do ?
9 REPLIES 9
Message 2 of 10
in reply to: yes_and_no
Post the family you are working on.
Message 3 of 10
yes_and_no
in reply to: barthbradley
Anyone ?
R17 families uploaded.
I ve been able to model in place the ESE with correct orientation, but that's not what I want. The point is how to imbed a child family with correct orientation. Thx
Message 4 of 10
What's wrong with these two orientations:
Message 5 of 10
yes_and_no
The points are :
- reserve the electrical panel setting, for scheduling, etc.
- be able to parametric the ESE ht, y/n, etc.
I don't see it in yr pix.
Message 6 of 10
@yes_and_no wrote:
The points are :
You didn't mention any of that, and unfortunately, my mind-reading capabilities have expired.
If you want answers, I need you to explain what you mean by:  "reserve the electrical panel setting, for scheduling, etc." and "be able to parametric the ESE ht, y/n, etc.".
Message 7 of 10
Use a work plane or face based, NOT a two level based, for the nested family.
Message 8 of 10
There are no nested families in either one of the families you posted. Were you expecting someone to do that work for you?   That is, were you expecting someone to nest one family into the other - and then clean up the Parent Family (e.g. remove unnecessary/redundant geometry?
Message 9 of 10
yes_and_no
My families are R17, so I don't expect anything from your work, probably in current version.
Message 10 of 10
Well, you were expecting something. You posted two families for us to look at.
Forma Design Contest
