Annoying issue, right before my final is due for university
wjon0005
Message 1 of 9
wjon0005
Hey all,
Ive come across this issue today, and also conveniently at the worst possible time for me.
Upon opening revit 2024, im hit with the clock error message, which im used to at this point, ive been able to troubleshoot that issue quite easily, this time however, the error persisted, even when i went as far to manually refresh the "Auto Time zone updater" in Services, i soon realised after this that the licensing issue prompt came up after clicking "x", which i have never seen before. Following this, i did a variety of troubleshooting such as uninstalling and re-installing, and doing the same for Autodesk access service host,
Here is proof of trying to re-install a variety of files in attempts to get Revit working again, but the same errors are prompted still, i cant get to the bottom of the issue, i dont know if its a time issue, an internet issue, or an actual licensing issue.
Any help would be greatly appreciated. thanks
Replies (8)
Message 2 of 9
vitorbortoncello
try installing another version
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 9
wjon0005
Ive downloaded Revit 2025, and upon opening the software, im met with just the clock error prompt, and no licesne error prompt
Message 4 of 9
vitorbortoncello
Message 5 of 9
HVAC-Novice
offtopic.. but I like the way you marked this up. What tool did you use to create/edit this screenshot?
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 6 of 9
vitorbortoncello
it is not off topic, i just copied it from here (clock error solution)
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clock-Error-Check-...
Message 7 of 9
HVAC-Novice
Oh, I guess I have to ask Autodesk how they did the mark-up and preparation of the screenshot in such a nice way 🙂
Message 8 of 9
SteveKStafford
Looks like SnagIt by Techsmith
Steve Stafford
Message 9 of 9
handjonathan
hi @wjon0005 As @SteveKStafford suggests, this is SnagIt
Jonathan Hand
Technical Marketing Manager | Construction
