Roof Thickness Error Message
1 ANTWORT 1
Nachricht 1 von 2
jmahmoud9LQBV
113 Aufrufe, 1 Antwort
Hello, I'm faced with an error message stating that my roof thickness is too thin and therefore cannot be sloped. When I modify sub elements, the points should be 0,0 instead of 60 ft 8 1/2". What could possibly be the reason for this? Any help would be greatly appreciated.Roof Thickness Error Message Part 1.jpgRoof Thickness Error Message Part 2.jpg
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: jmahmoud9LQBV
The point is at 60 feet above the project base point.  Choose the other option using base of roof and it should be 0.  You can share the model here so we will see what cause the error.
