Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
What is tool use for create Assembly code text file in Revit
infraworksvnr01
infraworksvnr01
Hi Guy,
I want to create assembly code for Revit.
Can you talk to me What is tool use for create Assembly code text file in Revit?
jay_colcombe
These are based on Uniformat codes as described below;
Help | Add or Change a Uniformat Assembly Code | Autodesk
As shown in the link you can either Edit the Family directly or alternatively you could use the Autodesk Interoperability Tools for Revit the links are below and using the Standardized Data Tool you can assign Classification through this way.
Autodesk Standardized Data Tool for Revit
Jay Colcombe
Autodesk Certified Instructor
azad.Nanva
I used the Excel to make the basis of Assembly code file and then , i needed to convert the Excel file to Assembly Code File and I use the Dynamo for it , you can use every programing languages.
handjonathan
Hi @infraworksvnr01
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford @azad.Nanva helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
