Allignament between structural beams with roof and beams at ridge on the roof
Message 1 of 16
there possibility to allign beams and roof?
And manage the two beams at the ridge on the roof that overlap each others?
.rvt file is attached.
Thank's
Replies (15)
Message 2 of 16
MostafaElashmawy
You will need to draw the beam longer then draw a reference plan and cut with it.
Mostafa Elashmawy
Message 3 of 16
@MostafaElashmawy
With which commadn cut?
With "split element" doesn't go.
Message 4 of 16
Message 5 of 16
A scrrencast, please?
Message 6 of 16
MostafaElashmawy
Screencast uploading
Mostafa Elashmawy
Message 7 of 16
MostafaElashmawy
Mostafa Elashmawy
Message 8 of 16
RDAOU
Make sure not to delete the ref plane or you will lose that cut
Message 9 of 16
@MostafaElashmawy  thank's a lot for screencats. I've confused "set work plane" with "reference plane".
But for the ridge on the roof?
I've hidden the fisrt beams and the cut.
Is the better way?
With 3D views can't cut geometry?
Thank's
Message 10 of 16
RDAOU
You do not need a reference plane at the top the Beams join automatically...
Mirror this beam and see what happens 😛
Message 11 of 16
MostafaElashmawy
What @RDAOU  should work for you if the right beam system is exactly similar with the left ones but as they are slightly different, you can use the cut tool to cut both the right and the lift beam by the reference plan.
cut>>1st beam>> .ref plan
cut>> 2nd beam>> .ref plan
Mostafa Elashmawy
Message 12 of 16
MostafaElashmawy
Mostafa Elashmawy
Message 13 of 16
@RDAOU  if i mirror I do not obtain what you have sayed
Message 14 of 16
@RDAOU this is how join automatically?
I undrestand for down side mirroring. Have to mirrow also reference plan with beam system.
Message 15 of 16
RDAOU
Build the cut in the beam family...
Message 16 of 16
Mirror the beams and the ref planes altogether. You can group them and mirror.
Annotation 2020-01-14 094118.jpgAnnotation 2020-01-14 094131.jpgAnnotation 2020-01-14 094145.jpg
