hi I am quite new to revit so my question might be stupid....
when I use demolishing tool, when I demolish a door or window, there are black lines on the opening, instead of red lines I want. How can I set the revit so these lines are red when I demolish door or windows? thank you very much in advance!
PS: please see the attached image then you can see what I mean.
Solved by RDAOU. Go to Solution.
The thick black lines indicate the new wall infills because the doors are demolished. They are correct.
Toan Nguyen
Thank you very much for your reply! I now understand it is wall infill....but how can I turn it into red? is there anyway we can do this? except using linework tool? I prefer to do it in settings so that I dn't have to change it manually every time?
If you intend to show only the demolished and existing (ie: Demo Layouts) then simply change the Phase Filter and opening Infills will be gone (See image below)
Note: the red overhead lines are symbolic projection lines from the family (not the infill)
