Hi All
Just wondering if it's possible to have these curtain wall panels joining just like how the walls are trimmed?
or I have to turn them into normal walls to achieve that?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
refer to this LINK and see if helps. thanks
try this configurations , adjust your curtain panel manually and see if helps
Edit the curtain wall type and replace the Glazed Curtain Panels with a Basic Wall...subsequently you will have a seamless corner that can be mitter joined
Thanks. One side of the wall just don't mitre joint. After numerous attempts I found the trick. on the wall joint options bar click the disallow join then click on the corner again and allow join.
