mphungDCHNW
239 Views, 5 Replies
2D
How do you make 2D elements visible only in 2d but not in 3D is the visual option the only way?
5 REPLIES 5
in reply to: mphungDCHNW
2D Elements are not visible in 3D, so what do you mean?
Do you mean lines in a family?  Use symbolic lines instead of model lines then they will not show in 3D.
mphungDCHNW
in reply to: ToanDN
just wondering is a symbolic line ? what are its pros & cons ?
A symbolic line is just another name for a 2D line.  Goes by the name of Detail line as well.
Pros and Cons??? 2D vs 3D. It has 1 less "D", so it weighs less.  😉
Symbolic lines are 2D lines, only appear in the view parallel to the plane of the lines.
Pros and cons for what?
Forma Design Contest
Technology Administrators
