My door family does not have any options
3 ANTWORTEN 3
Nachricht 1 von 4
tpulice
189 Aufrufe, 3 Antworten
when I select the door icon, then click the load family there is no other door options that come up. I cannot get to commercial doors. I have a student version, is this why?
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
pendean
als Antwort auf: tpulice
Door Family? This is not the REVIT forum, if that is what you are using the correct forum is over here https://forums.autodesk.com/t5/revit-products/ct-p/2003
Nachricht 3 von 4
Go to Insert tab and press Load Family. Then look in the OOTB Content Library under "Doors". There's plenty to choose from.
...if yours is a new install, you may not have installed the content library.  Check here:
https://knowledge.autodesk.com/support/revit/downloads/caas/downloads/content/autodesk-revit-2022-co...
Nachricht 4 von 4
If you use Revit 2022 or 2023 you can load the content directly from Autodesk online library without installing.
