I would like to control the dimension of my dockablepane from a button inside. So the dockable pane is already register and showing.
I would like to try something like that but I can't figured out how to get DockablePaneProviderData :
DockablePane dp = application.GetDockablePane(new DockablePaneId(new Guid("{72D8323C-1A97-4C4A-BE99-5D7CE3098B57}"))));
//How to get DockablePaneProviderData from DockablePane
DockablePaneProviderData data = ???
Autodesk.Revit.DB.Rectangle rect = new Autodesk.Revit.DB.Rectangle(200, 200, 500, 1100);
data.InitialState.SetFloatingRectangle(rect);
Also do I need to use an event to call this code?
Thanks a lot!
André
I cannot see any way to achieve that either, so I asked the development team for you.
The DockablePaneProviderData is from the interface IDockablePaneProvider.
public void SetupDockablePane(DockablePaneProviderData data)
data.FrameworkElement = this;
data.InitialState = new DockablePaneState
DockPosition = DockPosition.Tabbed,
The last time I tried to use SetFloatingRectangle was really bad, If you have two screens is hard to set in the middle or something. And that floating rectangle only gonna happen one time, after that Revit gonna remember where the user put the DockablePane.
Thank you!
It's a request from my client but I know it's not simple and I know Revit remembered the last position. But I tried to please my client.
André.
