Static UIApplication & ExternalCommandData DTOs
esatis
esatis
what are best practices with accessing UIApplication and ExternalCommandData ?
Do you use static DTOs, like these:
internal class RevitUiApplicationDTO
	public static UIApplication UiApp { get; set; }
	public static UIDocument UiDoc => UiApp?.ActiveUIDocument;
	public static Document Doc => UiDoc?.Document;
public static class RevitExternalCommandDTO
    public static ExternalCommandData CommandData { get; set; }
    public static UIApplication UiApp => CommandData?.Application;
this seems like easy solution that solves passing around the UiApp or CommandData.
I set it when i subscribe to Idling event, and it works with first manual tests.
public class IdlingEventHandler : IExternalEventHandler
	public void Execute(UIApplication uiApplication)
		uiApplication.Idling += IdlingHandler;
		RevitUiApplicationDTO.UiApp = uiApplication;
	public void IdlingHandler(object sender, Autodesk.Revit.UI.Events.IdlingEventArgs args)
		if (ChatInputPageIsValid())
			ProcessRequest(RevitUiApplicationDTO.UiApp);
		else
			UnsubscribeIdling(RevitUiApplicationDTO.UiApp);
Later when i would automate testing with Geberit Revit Unit testing https://github.com/geberit/Revit.TestRunner ,I would still set UIapp as DTO.
		[OneTimeSetUp]
		public void Setup(UIApplication uiApplication)
			Assert.NotNull(uiApplication);
  Will I get in trouble later down the road for using this method of passing the UIapp around ?
I use Idling event because all Commands will be initiated from Modeless docked pane.
ricaun
Using Idling is a good way to do it, tecnaly you only need to store the UIApplication once, and is good to go.
Today I converted the UIControllerApplication to UIApplication, so I don't need to worry about registering events.
Using this extension: https://github.com/ricaun-io/RevitAddin.DI.Simple/blob/master/RevitAddin.DI.Simple/Extensions/UICont...
public Result OnStartup(UIControlledApplication application)
	UIApplication uiapp = application.GetUIApplication();
Storing the ExternalCommandData is not a thing I do, ExternalCommandData is only used inside an IExternalCommand, kinda useless outside that context.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
