Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
DockablePane setFloatingRectangle
4 REPLIES 4
adcdao
253 Views, 4 Replies
adcdao
I would like to control the dimension of my dockablepane from a button inside. So the dockable pane is already register and showing.
I would like to try something like that but I can't figured out how to get DockablePaneProviderData :
DockablePane dp = application.GetDockablePane(new DockablePaneId(new Guid("{72D8323C-1A97-4C4A-BE99-5D7CE3098B57}"))));
//How to get DockablePaneProviderData from DockablePane
DockablePaneProviderData data = ???
Autodesk.Revit.DB.Rectangle rect = new Autodesk.Revit.DB.Rectangle(200, 200, 500, 1100);
data.InitialState.SetFloatingRectangle(rect);
Also do I need to use an event to call this code?
Thanks a lot!
André
Thanks a lot!
André
4 REPLIES 4
jeremy_tammik
in reply to: adcdao
jeremy_tammik
I cannot see any way to achieve that either, so I asked the development team for you.
adcdao
in reply to: jeremy_tammik
adcdao
Thank you Jeremy!
Thank you Jeremy!
ricaun
in reply to: adcdao
ricaun
The DockablePaneProviderData is from the interface IDockablePaneProvider.
public void SetupDockablePane(DockablePaneProviderData data)
    data.FrameworkElement = this;
    data.InitialState = new DockablePaneState
        DockPosition = DockPosition.Tabbed,
The last time I tried to use SetFloatingRectangle was really bad, If you have two screens is hard to set in the middle or something. And that floating rectangle only gonna happen one time, after that Revit gonna remember where the user put the DockablePane.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
adcdao
in reply to: ricaun
adcdao
Thank you!
It's a request from my client but I know it's not simple and I know Revit remembered the last position. But I tried to please my client.
André.
Thank you!
André.
