ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Recap output size and location are off when loaded into Civil 3d or Autocad 3d
3 REPLIES 3
TomLarson4638
311 Views, 3 Replies
I have imported a .las file into Recap Pro. Within Recap, everything looks fine - coordinate system is showing as UTM84-14N and the size of the image looks correct. However, when import into a CAD drawing set to the same coordinate system with the POINTCLOUDATTACH command, the coordinates are way off and the image is approximately 40 times too large. I'm working with .las files created from drone flights and processed through DJI Terra software.
3 REPLIES 3
Pointdump
in reply to: TomLarson4638
Hi Tom,
"...the coordinates are way off and the image is approximately 40 times too large."
Using Civil 3D? Before importing the RCP file, use command UNITS to set "Insertion Scale" to whatever your RCP units are. Don't use Unitless. UTM84-14N would be Meters.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
If it good in Recap, please use RCP file (not RCS) to import in civil3d and specify to use the attached CS with rcp. I’m assuming you have CS assigned in C3D drawing, if not please assign in project properties before importing. That should work.
Ramesh S
Product Manager - Infrastructure Solutions
Ramesh.Sridharan@autodesk.com
Ramesh Sridharan
Product Manager
Ramish and Dave, thanks for your input. Setting Units to meters solved the problem.
Rail Community
