.NET
quick selection of all "AcDbBlockReference".
7 REPLIES 7
Message 1 of 8
1714 Views, 7 Replies
Hello.
Does anyone know how I can get all the "Block Reference" from the drawing
Now I'm doing it like that ...
C#
public void GetBlkRef()
    foreach (AcadEntity Entity in ThisDrawing.ModelSpace)
        if (Entity.ObjectName == "AcDBlockreference")
or
VB.NET
Public Sub GetBlkRef()
    For Each Entity As AcadEntity In ThisDrawing.ModelSpace
        If Entity.ObjectName = "AcDBlockreference" Then
        End If
    Next
End Sub
but this method works slowly on large drawings.
How can I get quick access to all "AcDbBlockReference" objects?
Is there a collection with all the objects of "AcDbBlockReference"?
7 REPLIES 7
Message 2 of 8
_gile
if using the COM API is not mandatory, you can try using a filtered selection set (but I'm not certain it's faster, the model space have to be iterated anyway).
            // build the selection filter
            short[] filterType = { 0, 410 };
            object[] filterData = { "INSERT", "Model" };
            // create the selection set
            AcadSelectionSet selectionSet = thisDrawing.SelectionSets.Add("SSET");
            // select all block references in model space
            selectionSet.Select(AcSelect.acSelectionSetAll, Type.Missing, Type.Missing, filterType, filterData);
            // iterate through the selection set
            foreach (AcadBlockReference block in selectionSet)
                // do your stuff with selected blocks
                block.Layer = "1";
            // delete the selection set
            selectionSet.Delete();
If you could use the .NET API, iterating through the model space should be faster because you could check for the entity type directly from its ObjectId.
            // get the working database
            var db = HostApplicationServices.WorkingDatabase;
            // start a transaction
            using (var tr = db.TransactionManager.StartTransaction())
                // open the model space for read
                var modelSpace = (BlockTableRecord)tr.GetObject(
                    SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                var brclass = RXObject.GetClass(typeof(BlockReference));
                // iterate through the model space entity
                foreach (ObjectId id in modelSpace)
                    // check if the ObjectId refers to a BlockReference
                    if (id.ObjectClass == brclass)
                        // do your stuff with the block ObjectId
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
in reply to: _gile
Thank you very much.
I used the first example.
it works faster.
Do you know where I can find descriptions of all codes?
Message 4 of 8
_gile
These are DXF 'group codes' and data.
0 stands for: "Entity type" ("INSERT" here).
410 stands for: "layout name" ("Model" here).
You'll find the DXF group codes reference here.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
dalian_mudong
in reply to: _gile
I use vb.NET
Dim intCode() As Int16
Dim varData() As Object
Dim blockRefObj As AcadBlockReference
intCode(0) = 0
intCode(1) = 410
varData(0) = "INSERT"
varData(1) = "Model"
Selection_Set.Select(CAD_Int_Com.AcSelect.acSelectionSetAll, Type.Missing, Type.Missing, intCode, varData)
For Each blockRefObj In Selection_Set
Debug.Print(blockRefObj.Name)
Next
but Selection_Set.count=0
Nothing is selected
Why?thanks.
Message 6 of 8
dalian_mudong
Dim intCode(0 To 1) As Int16
Dim varData(0 To 1) As Object
Also does not work.
Message 7 of 8
Solved by myself
Message 8 of 8
Solved by myself
Forma Design Contest
