I have this code in C# where the code compiles perfectly but i do not see progress meter on ACAD UI.
[CommandMethod("PilePlacement")]
public static void Main()
doc = Application.DocumentManager.MdiActiveDocument;
ed = doc.Editor;
db = doc.Database;
try
// Show progress bar window on a separate thread
//progressBarThread = new Thread(() =>
// progressBarWindow = new ProgressBarWindow();
// progressBarWindow.Show();
// System.Windows.Threading.Dispatcher.Run();
//progressBarThread.SetApartmentState(ApartmentState.STA);
//progressBarThread.Start();
List<string> tableNames = MMSData.tables;
MMSData.tablePiling = true;
Dictionary <string, List < BlockReference >> allBlockReferences = MMSData.mmsTablesDict;
Log.Logger.Log("Get list of table names and dictionary of table name and blocks from MMSData");
//iterate through all the tables selected by user
//string[] tableNames = { "MMS Table (32.2920 x 4.5760)", "MMS Table (128.58 x 2.278)" };
Log.Logger.Log("iterate through all the tables selected by user");
// Start the progress meter
ProgressMeter progressMeter = new ProgressMeter();
progressMeter.Start("Placing piles...");
progressMeter.SetLimit(tableNames.Count);
foreach (string tableName in tableNames)
string currTable = tableName;
if(currTable.Contains("(Ext)")) currTable = currTable.Replace("(Ext)", "");
AddPileDrawingToDB(tableName, allBlockReferences[currTable][0]);
// Update the progress meter
progressMeter.MeterProgress();
// This allows AutoCAD to repaint
System.Windows.Forms.Application.DoEvents();
ChangeVisibility();
// Close the progress bar window on the UI thread
//if (progressBarWindow != null && progressBarWindow.Dispatcher != null)
// progressBarWindow.Dispatcher.Invoke(() => progressBarWindow.Close());
// Stop the progress meter
progressMeter.Stop();
MessageBox.Show("Piles placed successfully !!", "Piling Automation", MessageBoxButton.OK, MessageBoxImage.Information);
catch (Autodesk.AutoCAD.Runtime.Exception ex)
Log.Logger.LogException(ex);
catch (System.Exception ex)
//finally
// // Ensure the progress bar thread is closed
// if (progressBarThread != null && progressBarThread.IsAlive)
// progressBarThread.Join();
Solved by norman.yuan. Go to Solution.
ProgressMeter is not reliable visual indicator of looped code execution running. It would highly depend on what the code does and how AutoCAD/Windows OS decide when some of AutoCAD window components being updated. From my years of .NET plugin development experience, the only reliable way to show visual progress of looped AutoCAD code execution is to use MODAL form, as @ActivistInvestor suggested in your other post, which you have accept as the solution to your question.
Thanks for the insight. I have created Modal WPF window for that purpose but I was trying to exploit inbuilt ProgressMeter class for the said purpose. Again Thanks for info.
