Hello.
Does anyone know how I can get all the "Block Reference" from the drawing
Now I'm doing it like that ...
C#
public void GetBlkRef() { foreach (AcadEntity Entity in ThisDrawing.ModelSpace) { if (Entity.ObjectName == "AcDBlockreference") { } } }
or
VB.NET
Public Sub GetBlkRef() For Each Entity As AcadEntity In ThisDrawing.ModelSpace If Entity.ObjectName = "AcDBlockreference" Then End If Next End Sub
but this method works slowly on large drawings.
How can I get quick access to all "AcDbBlockReference" objects?
Is there a collection with all the objects of "AcDbBlockReference"?
Solved by _gile. Go to Solution.
if using the COM API is not mandatory, you can try using a filtered selection set (but I'm not certain it's faster, the model space have to be iterated anyway).
// build the selection filter short[] filterType = { 0, 410 }; object[] filterData = { "INSERT", "Model" }; // create the selection set AcadSelectionSet selectionSet = thisDrawing.SelectionSets.Add("SSET"); // select all block references in model space selectionSet.Select(AcSelect.acSelectionSetAll, Type.Missing, Type.Missing, filterType, filterData); // iterate through the selection set foreach (AcadBlockReference block in selectionSet) { // do your stuff with selected blocks block.Layer = "1"; } // delete the selection set selectionSet.Delete();
If you could use the .NET API, iterating through the model space should be faster because you could check for the entity type directly from its ObjectId.
// get the working database var db = HostApplicationServices.WorkingDatabase; // start a transaction using (var tr = db.TransactionManager.StartTransaction()) { // open the model space for read var modelSpace = (BlockTableRecord)tr.GetObject( SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead); var brclass = RXObject.GetClass(typeof(BlockReference)); // iterate through the model space entity foreach (ObjectId id in modelSpace) { // check if the ObjectId refers to a BlockReference if (id.ObjectClass == brclass) { // do your stuff with the block ObjectId } } tr.Commit(); }
Thank you very much.
I used the first example.
it works faster.
Do you know where I can find descriptions of all codes?
These are DXF 'group codes' and data.
0 stands for: "Entity type" ("INSERT" here).
410 stands for: "layout name" ("Model" here).
You'll find the DXF group codes reference here.
I use vb.NET
Dim intCode() As Int16
Dim varData() As Object
Dim blockRefObj As AcadBlockReference
intCode(0) = 0
intCode(1) = 410
varData(0) = "INSERT"
varData(1) = "Model"
Selection_Set.Select(CAD_Int_Com.AcSelect.acSelectionSetAll, Type.Missing, Type.Missing, intCode, varData)
For Each blockRefObj In Selection_Set
Debug.Print(blockRefObj.Name)
Next
but Selection_Set.count=0
Nothing is selected
Why?thanks.
Dim intCode(0 To 1) As Int16
Dim varData(0 To 1) As Object
Also does not work.
