Migration Guide: .Net Framework to AutoCAD 2025/.NET 8.0
_gile
Consultant Consultant
Message 1 of 75
_gile
I tried to write a basic step by step migration guide in French. If anyone has the courage to translate it into proper English (I can provide the .docx file if needed)...
Gilles Chanteau
GileCAD
GitHub
Replies (74)
Message 2 of 75
Jeff_M
I have created an English translation of the migration guide @_gile posted.
Jeff_M, also a frequent Swamper
Message 3 of 75
Ed__Jobe
Thanks @_gile and @Jeff_M
Ed
How to post your code.
Message 4 of 75
kerry_w_brown
Thanks Gilles,
Thanks Jeff,
@Jeff_M
I think the Launch Profiles => Command Line Arguments should be
/nologo /b "start.scr"
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 5 of 75
Jeff_M
@kerry_w_brown good catch!
Message 6 of 75
Alfred.NESWADBA
thank you both @_gile & @Jeff_M !
Let me add one experience I had, referring to the list of files to be used for conversion:
I had a situation where I selected a VBProj-file to be converted and the converter listed all VB-files inside the folder, and not just the ones, that were part of the VB-project. Letting all files checked (in the list of files, where checkboxes are shown) will result in having all the files added to the new/converted project.
I had not done a lot with the converter, but that happened during my tests twice, so not just one time and one project.
Maybe that with C# that works better. But be careful about that.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 75
Alfred.NESWADBA
may I ask a question regarding the output folder?
Now it adds automatically "net8.0-windows" as subfolder to the destination folder I set in the project settings.
Has anyone found an option to not do that? Our apps-output-folders are quite strong structured in directories per AutoCAD version, having now subfolders would kill this structure (which was working really well since beginning of AutoCAD with .NET Framework)
- alfred -
Alfred NESWADBA
Message 8 of 75
kerry_w_brown
@Alfred.NESWADBA
Try :
https://learn.microsoft.com/en-us/visualstudio/ide/how-to-change-the-build-output-directory?view=vs-...
ADDED:
perhaps this would suit you too
https://learn.microsoft.com/en-us/visualstudio/ide/specifying-custom-build-events-in-visual-studio?v...
Message 9 of 75
_gile
@Alfred.NESWADBA
You can add this PropertyGroup to the .csproj/SDK file.
<PropertyGroup>
	<AppendTargetFrameworkToOutputPath>false</AppendTargetFrameworkToOutputPath>
	<AppendRuntimeIdentifierToOutputPath>false</AppendRuntimeIdentifierToOutputPath>
</PropertyGroup>
See this topic.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 75
kerry_w_brown
@Alfred.NESWADBA
As well as the link Gilles mentioned, perhaps have a look here too :
Message 11 of 75
ziggy63
Hi Gilles,
Thank you very much for the guide. I tried to follow your instructions but the upgrade of all my vb projects failed, with the following error message:
Does this message mean anything to you? What am I doing wrong? Has anybody else encountered this error?
Thank you in advance,
George
Message 12 of 75
Alfred.NESWADBA
@_gile
Wow, searched for that, but was not able to find this link.
Thank you so much!
- alfred -
Alfred NESWADBA
Message 13 of 75
_gile
@ziggy63 wrote:
Hi Gilles,
George
Never seen that message before. It seems to be an error with the Upgrade Assistant.
Gilles Chanteau
GileCAD
GitHub
Message 14 of 75
ziggy63
So, I seem to be the only person on planet Earth who cannot upgrade a VB project from .NET Framework to .NET, using Microsoft's own tools! Now, this is interesting...
Message 15 of 75
Alfred.NESWADBA
are you sure that you have installed the .NET 8.0 SDK?
I have had messages similar to yours (not sure if that really were the same), before I installed this SDK (I just was looking into the VS2022 installed parts (tools and features) and have seen ".NET 8.0 Runtime (Long Term Support)" aas well as ".NET SDK" and thought, that should be enough. Later I recognized that this is not all that is needed and installed the "real" .NET 8.0 SDK from here: >>>click<<< for downloading .NET 8.0 SDK (v8.0.203) - Windows x64 Installer!
HTH, - alfred -
Alfred NESWADBA
Message 16 of 75
ziggy63
Hi Alfred,
I reinstalled the SDK, using the link you sent me, but the problem persists.
Thank you anyway.
Message 17 of 75
_gile
No, you're not alone:
https://stackoverflow.com/questions/77932310/net-upgrade-assistant-error-when-converting-csproj-file...
https://stackoverflow.com/questions/78141705/net-upgrade-assistant-fails-on-converting-project-to-sd...
Gilles Chanteau
GileCAD
GitHub
Message 18 of 75
ntclmain
Thank Gile.
Relating the Migration guide, I've found some pieces of information from Autodesk Civil 3D 2025:
Known Issues in Civil 3D .NET Core Development
https://help.autodesk.com/view/CIV3D/2025/ENU/?guid=GUID-B50CC834-E202-48FE-9C64-526EF9828535
Plugin fails to load due to the lack of a framework reference to Microsoft.AspNetCore.App
Civil 3D does not rely on Microsoft.AspNetCore.App, so it has not added this reference. If your plugin has a dependency on it, it may prevent the plugin from running.
Solution: Edit the acdbmgd.runtimeconfig.json file located in the Civil 3D root folder by adding a reference to Microsoft.AspNetCore.App. If you are using a script or installer to add it, incorporate logic to check whether the user or other plugins have already included it before adding it to avoid duplication. Also, ensure that the desired version has been installed by Civil 3D using the "dotnet --list-runtimes" command. Otherwise, you may consider including the framework installer within your plugin installer. ..."
About Civil 3D .NET Core Development
https://help.autodesk.com/view/CIV3D/2025/ENU/?guid=GUID-E6657034-71E5-4753-8AFD-139DC612B86D
.....As per claims such as https://github.com/dotnet/runtime/issues/68041, .NET framework DLLs could continue to work within .NET Core runtime as long as they don't use any API exclusive to .NET Framework, However, you should conduct thorough testing on your own to ensure it functions properly within the .NET Core environment if you choose to stay with .NET framework." ....
I wonder why those information does not appear in AutoCAD 2025 ".NET migration guide"
https://help.autodesk.com/view/OARX/2025/ENU/?guid=OARX-ManagedRefGuide-_NET_Migration_Guide
Previously, I've tested my .NET Framework 4.8  libraries in AutoCAD 2025 (by mistake).  My project is multi targets and I load the wrong file.  It works so smoothly that I didn't find that the wrong version is loaded, until I found commands under   #If NET5_0_OR_GREATER   directive do not work as expected.
However, another guy in feedback forum (Alexandr Chernishev) reported that his plugin could launch, work, then the error “SQLClient file not found” popped up.
Message 19 of 75
Norman_Yuan
Thanks for the efforts and contributions from @_gile and @Jeff_M. It is a big help.
I thought it might be even better if the guide includes some general suggestions on whether to migrate or not, because many AutoCAD programmers coming to here are not fulltime or career-programmers, some may be quite new to AutoCAD programming, so the evolving history of .NET technologies and AutoCAD .NET API could be rather confusing. It is certain that Autodesk's very poor .NET Migration Guide documentation does not help much at all.
Here are some of my thoughts:
1. Many existing .NET plugins based on .NET Framework (4.x) should work with AutoCAD 2025 just as they work with prior AutoCAD versions. Of course, it depends what the .NET Plugins do, so, they have to be fully tested. But it is important to know: the common sense of "if it aren't broken, do not fix it" should be paly a big role in making migration decision;
2. Not all projects need to be migrated to .NET 8, if the plugin is meant for multiple versions of AutoCAD (which would be true to most existing projects since AutoCAD 2025 is just out).
  • For bug fixing of existing plugins, if it works OK in AutoCAD 2025, we can still fix/debug it with existing .NET 4.x project and compile it, so it remains as single set of code that works with older AutoCAD version and Acad2025; It is also possible to enhance the plugin with new feature and still working with older Acad and Acad2025.
  • If the existing plugin is indeed broken with AutoCAD 2025, then the migrate to .NET 8 is necessary, if the plugin needs to run with Acad2025. But in this case, in order to support older AutoCAD, 2 sets of code are in .NET 4.x project and .NET 8 project respectively.
  • For the project migrated to .NET 8, or a new project created in .NET 8, it will not run with older AutoCAD version prior to Acad2025.
So, I think it would quite important to realize that at this stage (that is, majority of AutoCAD users will still use AutoCAD 2024 or older for quite a while) that continuing to maintain existing plugins with .NET 4.8 would last for foreseeable period, as long as the existing plugins work ok in older AutoCAD versions and AutoCAD 2025. Only do the migration if the target AutoCAD version is 2025 or newer.
Norman Yuan
Drive CAD With Code
Message 20 of 75
SENL1362
May i add: You also need to upgrade to .NET Core if you want to use the new features of C# 8 and higher.
