Migration Guide: .Net Framework to AutoCAD 2025/.NET 8.0
_gile
Consultant Consultant
Message 1 of 70
_gile
I tried to write a basic step by step migration guide in French. If anyone has the courage to translate it into proper English (I can provide the .docx file if needed)...
Gilles Chanteau
GileCAD
GitHub
Replies (69)
Message 21 of 70
imranGJ2WC
After Migration as suggested by @_gile , it migrated successfully. The converted project is recompiled successfully and even loaded using NetLoad. But the WPF Modal Windows are not working. It shows the following message on AutoCAD 2025.
On the other hand, the WinForm works well.
var dia = new testFRM();
var result = AcAp.ShowModalDialog( dia);
But the following code shows the above message about cer-dialogue.exe and a runtime exception.
Any Idea about this ?
Message 22 of 70
_gile
@imranGJ2WC Have a look at this page.
Gilles Chanteau
GileCAD
GitHub
Message 23 of 70
imranGJ2WC
@_gile Thanks for the reply.
But this did not solve the issue.
It seems that AutoCAD 2025 .Net API does not support WPF Windows as Model Dialogues/Windows. It only supports winforms. Mostly, we use WPF windows with MVVM approach. So it is nightmare to convert all WPF UIs to Winform windows.
If anyone has tried it ?
Message 24 of 70
_gile
I did try it, and have no problem migrating WPF / MVVM dialogs or palettes to AutoCAD 2025 / .NET 8.0.
Gilles Chanteau
GileCAD
GitHub
Message 25 of 70
Jeff_M
My WPF windows and usercontrols all work fine in .NET8, both Modal and Modeless.
What is the exception you get? Showing some code that fails may help.
Jeff_M, also a frequent Swamper
Message 26 of 70
imranGJ2WC
@Jeff_M @_gile
var dlg = new MyView();
MyView() is a WPF Window. When program enters in the constructor and InitializeComponent() is called, it raises the following exception.
Thanks in advance.
Message 27 of 70
_gile
I've never seen such code before. Do you use some third-party application?
Gilles Chanteau
GileCAD
GitHub
Message 28 of 70
Jeff_M
@_gile that is the decompiled accoremgd.dll code.
@imranGJ2WC Can you post the actual .xaml & .xaml.cs files? Along with the code that calls the loading of the window?
Message 29 of 70
imranGJ2WC
@Jeff_M
The code is quite simple. Attached ZIP file contains two projects .. One is .Net Framework 4.8 and other is .Net Core (Migrated according to the document shared by @_gile ).
The Core Project contains a WPF Window. The project compiles successfully but the WPF window does not load and AutoCAD crashes.
Message 30 of 70
_gile
It looks like you did not replace the AutoCAD libraries (Autodesk_ObjectARX_2019_Win_64_and_32_Bit) in the upgraded project.
You have to download ObjectARX 2025 and reference the libraries from there.
Gilles Chanteau
GileCAD
GitHub
Message 31 of 70
norman.yuan
It is obvious: your updated project has references to OLD(!) AutoCAD .NET managed assemblies: they HAS TO BE AutoCAD 2025's assemblies.
Norman Yuan
Drive CAD With Code
Message 32 of 70
imranGJ2WC
@norman.yuan @_gile @Jeff_M
After replacing the Autocad references to 2025 SDK, still an exception occurs.
Message 33 of 70
norman.yuan
Well, that is a trick issue: you need to clear the "Assembly version" field in the Project properties -> Package tab, where somehow it has "24.4.8.4" in it (or click the "gear box" icon to clear/reset it).
BTW, I would prefer  not to do "Upgrate" the project from .NET framework to .NET 8, after trying the upgrade process. I'd rather create a empty .NET project/solution, add necessary references/nuget packages, and then copy the CS files to be included to the project.
Norman Yuan
Drive CAD With Code
Message 34 of 70
kerry_w_brown
 That is my preference too Norman.
 It's also my preference not to attempt sharing code between framework and net builds.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 35 of 70
imranGJ2WC
@norman.yuan
Yes. Sir. That was the issue. I just reset the assembly version and everything is working like a charm. You made my day.
We can not add a new WPF Window when working in a class library project (.Net 8.0) .. For this, I will always need to create/design it first in .Net Framework Project and add it as Existing File in .Net 8.0 project.
Message 36 of 70
_gile
For sure you can. Starting with this template (AutoCAD R25 Plugin Template), I just added a <UseWPF>true</UseWPF> node to the first PropertyGroup one, compile and Add > New item...
Gilles Chanteau
GileCAD
GitHub
Message 37 of 70
imranGJ2WC
@_gile Thanks. That's really a great Template.
After fixing the Assembly Version issue as suggested by @norman.yuan, WPF Window can be added.
Message 38 of 70
gleeuwdrent
My plugins are used in multiple versions of AutoCAD and verticals. Am I correct that after migration to .NET 8.0 we cannot have a single Visual Studio solution with all code, and built it on the .NET Framework and .NET 8.0 target? So to be compatible with 2024 and prior and 2025, I need to maintain two solutions and when I want to change/update code, change both solutions? Or is there a way to have a single source of code and use it both in 2025 and 2024/prior?
Message 39 of 70
_gile
You can try share the same code for boths projects (in the same solution) by "linking" the code files from the original project (.NET Framework) to the new one (.NET Core).
This can be done with the  Migration Assistant by choosing "Side-by-side incremental project upgrade" or by adding a new .NET 8 project to the solution and adding the code files from the original one using Add > Existing Item and Add as link option.
In both cases, you may have some errors with parts of code in the new project which can be solved by using conditionnal compilation.
Gilles Chanteau
GileCAD
GitHub
Message 40 of 70
imranGJ2WC
@gleeuwdrent
You can maintain two projects in one solution.  For this, you must import the source files in  .Net Core project as a Link from .net Framework project. In case if there is different code for both projects, you can use Conditional Compilation Symbols ( see https://forums.autodesk.com/t5/net/developing-plugin-for-autocad-and-bricscad/td-p/10627700 and https://alexeispirit.blogspot.com/2012/06/multi-cad-coding.html).
This will enable you to maintain the common code between both projects.
